Old 05-31-2007, 10:37 AM   #25
bsa633
Banned
Default
It is my "noname" opinion that it should be harder to run way under the index then it is now...either that you factor combinations were they should be...improved tech like enginessguy mentioned may be worth something.and is needed..but that aint gonna happen so the only option to sqare things out a little right now is to lower indexes somewhat..may be one way to really se what the combos are capable of beacuse now most racers dont care about the record anymore,the hard work is only gonna render in more lead in the car,10 years ago the record meant everything to a true classracer!!! Sean..sorry if you took it personal but all people cant afford this type of racing if they want a upperclass car or choose a heavy populated class,like i cant afford pro stock,but this is classracing...not bracketracing...and there are low buck alternatives if you look and IHRA has Pure Stock! This is gonna be my "noname" opinion as long as i do this!!! look at the div 1 race,27 didnt get to race in stock...if you took .30 off the indexes..almost all still would have gotten to dial under if they have raced...so whats the point....that you can come in with a rentalcar and make some rounds if your own car broke or some other snag???
bsa633 is offline   Reply With Quote
