Old 07-14-2010, 08:48 AM   #11
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: "7" Plymouth's You Just Had to Have.
I think HEMIDARTDAVE wins the actually owned "7" car Plymouth list.
Well over a Million $ in cars. Todays dollars.
Had to add one more to the list.
1965 Plymouth Valiant V-200 Sedan 273/235HP Commando 4-speed.
The fastest and lightest 273 Commando at 2714 lbs.
A perfect 11.55 wt/hp break.
In 65' with the true Hurst shifter and linkage, and that hollowed out
low-restriction muffler along with 3.91 optional gears.gears.
Capable of 15.10's, right off the dealership lot.
If you knew had to order one back then, you couldn't get the Formula S package on the Valiant (which was available on the Barracuda's), but you
could order the Performance group package with a special order (Firm-Ride HD shocks, heavy-duty 6-leaf rear springs, HD front sway-bar and wider wheel rims 5" x 14"), as well as the
8 3/4" Sure-Grip Posi rear.
PC
