Old 02-25-2010, 03:56 PM   #34
Jim Cassels
Default Re: how much do build this to a stocker??
Colton,
Don't get too excited about that motor. It went .7 under in a camaro 10 yrs. ago, it was a F.I. motor rated at 230 hp, m/sa then. In your car with a qudrajet it is rated at 254 hp which will be k/sa. As you can see you will have to move up to k which is .2, add aprox 100 lbs which is .1 and NHRA lowered the indexs .3 , so I am sure it would not run the index as it is now. It was running when removed from a Malibu I have but it will need a lot of work. Yours if you wont it.
Jim
PS
Tim you have heard of Montazomas revenge, well that was General Robert E. Lee's revenge. Hope you are doing well. LMAO
Jim
Jim Cassels is offline   Reply With Quote
