Old 11-07-2009, 11:12 AM   #1
partsbob67
Liked 79 Times in 11 Posts
Default Re: Gapless Rings - Are they worth it?
i put them in my engine last year and had nothing but problems. i won't run them again.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 11-07-2009, 06:47 PM   #2
Notch1320
I have them in my car.... they have given me no issues?
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 11-07-2009, 08:11 PM   #3
Bub Whitaker
Gapless Top.. work fine on engines that operate under 7500...BUT... cylinder finish, end gap, breakin procedure, is critical ! ! ! You need to listen to your engine builders advice if you want to try these on you own... you can't just put them in and expect to gain if you don't follow the path. Yes they are worth it, look at my accomplishments
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 11-07-2009, 08:53 PM   #4
Jeff Lee
Jeff Lee's Avatar
I know of a racer that held the record with both the top and second ring being gapless. I had gappless top rings in my turbo II 2.2L record holder. My Stock / Super Stock RWD engines have all had gapped rings. As Bub says, follow the advice of your engine builder. If you go against his advice then your on your own and if the project fails or succeeds it's on your shoulders. This is one of those areas where you have to make your own decision and stick to it. There are too many variables that go into making it work...or not.
Jeff Lee 7494 D/S '70 AMX
Old 11-08-2009, 09:08 AM   #5
RJ
Bub, what did you see above 7500 with the gapless tops? I used them in a restrictor plate motor, it ran very well up to 8200, the exhuast ports were dry, and did not seem to have any issues.
RJ is offline   Reply With Quote
Old 11-10-2009, 10:02 AM   #6
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Wink Re: Gapless Rings - Are they worth it?
Listen to Bub ....
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
