Old 11-07-2009, 08:11 PM   #4
Bub Whitaker
Default Re: Gapless Rings - Are they worth it?
Gapless Top.. work fine on engines that operate under 7500...BUT... cylinder finish, end gap, breakin procedure, is critical ! ! ! You need to listen to your engine builders advice if you want to try these on you own... you can't just put them in and expect to gain if you don't follow the path. Yes they are worth it, look at my accomplishments
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
