Old 10-28-2009, 05:38 PM   #14
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Default Re: Towing Help??
Originally Posted by Bill Harris View Post
AMEN Dick Butler!! The pressure in these trailer tires is absolutely the most important aspect of towing our junk.
I'm unfortunate that I didn't do my research before buying my trailer and have two 5200 lb axles on a 26 footer. It came with Goodyear Marathon and I blew the hell out of tires trip after trip. I discovered this notice from Goodyear:
http://goodyear.com/rv/pdf/marathon_gen_info_032806.pdf
I run the 15" ST225 tire at 70psi cold. Since then I monitor the tire pressure EVERY time I stop and EVERY time before pulling out to or from a race. I even pull over into rest areas occasionally just to check the tires. Since then, I have not had a single blow out (knock on wood... next trip I'm doomed). I also try to pull no faster than 65, and NEVER go over 70 (fortunately my motorhome is hard pressed to go that fast unless its falling off a cliff).
Next trailer will have the heaviest load rated axles and tires I can get even if I'm not hauling anywhere near the rated load.
Don't skimp on the axles and tires!!!
Bill, you might want to upgrade to a 16 in. tire.. I kept having problems with the 15 in. tires then decided to bite the bullet and upgraded to a 16 in. Worth the piece of mind!
It might have been Jeff Teuton that said the cheapest 16 in. tire is better than the best 15 in. tire.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
