Old 10-27-2009, 05:18 PM   #1
7820
7820's Avatar
Default Re: Towing Help??
What Art said.
7820 is offline   Reply With Quote
Old 10-27-2009, 05:43 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
You are really on the edge. A dually would be much better. More gvw, but much better stance for such a big trailer. Is the 32 2 axle or 3?
Jeff Teuton 4022 STK
Old 10-27-2009, 06:21 PM   #3
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
I tow my 32' with a 3500 Dodge diesel. No lounge but carry a golf cart, tools, 3200 lb car and all the "other stuff". Going is not the problem.. Its stopping. Last time out I had a OH SH-T stop and it was all the dually wanted. Even with brakes on all 4 wheels of the trailer... Just my $0.02 worth......
Mack Reeves
2377 STOCK & SUPER STOCK
Old 10-27-2009, 07:10 PM   #4
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Anyone using a 4500 series Dodge or Ford.They look reasonably sized compared to the monsterous
Chevy 4500.They also have 19 1/2" tires and big brakes.Also a bigger pricetag.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 10-27-2009, 07:28 PM   #5
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
I have almost the same set up, and I have had 2 Oh sh-- stops. I was wishing for a bigger truck then too. Mine isnt loaded as heavy as some I have seen, but its up there due to the trailers weight alone. Having brakes on 3 axles would be great, as I have 2, but I think the bigger issue, at least now days, is the legality of it. IF, you did , and I mean it could happen, have an accident, you may be held liable, with the truck being too small for your overal GVW. All it would take is one wiseass to change lanes at the wrong time to cause a huge mess, and you could be answering to a summons.
Your truck, like mine, has a 9200 GVW rating, and the truck is almost 7K by itself. Almost every Dualie has at least a 10K rating, but the extra brakes and extra pair of tires on the ground more than make up for the 800 lb difference.
2894 STK
Old 10-27-2009, 08:02 PM   #6
Jeff Teuton
Bob, get the 16" wheels & tires on the new trailer. You can usually order the 6 hole 16. The brakes are the same on the 5k and 6k axles. The diff is the outer bearing and 6 or 8 lugs. And don't get the 'st' tires. They are really bad.
Old 10-27-2009, 08:26 PM   #7
T Hall
T Hall's Avatar
I just purchased a 1994 Chevy dually with a 454 and I am very dissapointed with the pull. I am pulling a 26ft W&M with my Nova Big block, tools and scooter. On take off, it is a pig, especially on any type of a grade. My Z71 with a 5.7 vortec pulled better. Any worth while power advice? I have some under drive pullies that I still need to put on, maybe exhaust.
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
Old 10-27-2009, 08:34 PM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Towing Help??
Jeff, correct me if I'm wrong, but 6k and 7k brakes are the same. 5k is a smaller size, unless there is a bigger optional brake assembly.
Although I haven't researched it further, I was told that 6k drums have smaller wheel studs than 7k!
Might as well get 8 lug 16" wheels because they may be easier to find replacements for.
LOCOMOTION Racing
Old 10-28-2009, 10:11 AM   #9
Bobby Brannon
Liked 104 Times in 35 Posts
Bob, please give me a call @ 318-422-4646. I need to run something by you
Bobby Brannon 4705 STK, SS
Bobby Brannon is offline   Reply With Quote
Old 10-27-2009, 07:10 PM   #10
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
It would be eather. i have not ordered a trailer yet.
