Liked 564 Times in 66 Posts
Also important to note is OEM pulley's only! No aftermarket! No playing with Belt and groove widths.
Bill |
exactly right Bill, it should also state that the tensioners must be OEM as well
Chad Rhodes 2113 I/SA |
Liked 11 Times in 4 Posts
Why should the tensioner have to be OEM?
Tim Kish 3032 SS/GS |
the OEM tensioner is spring loaded. Metco and others make tensioners that are positive acting, and act on a different place on the belt thus increasing boost by eliminating any slippage. The tensioner should at minimum have to be of OEM type (spring loaded) and should be in the stock location
#5 | |
Jeff Lee 7494 D/S '70 AMX |
Liked 393 Times in 153 Posts
Oh puulease! Then I'll run a belt soaked in belt dressing that has zero slip.
Man the hating is so obvious! I wish obama motors and fiat would hurry up and field their pony cars........ |
there is no "hating", i just know what the supercharged mod motors are capable of. I do applaud NHRA for specifying the pulleys finally.
Chad,
The pulley spec has always been there, just not published. However, I do not know if they were checking them. Bill |
#9 | |
#10 | |
if the factory tensioner is spring loaded, so should whatever tensioner that is on it. otherwise its kinda like putting solid roller lifters on a hyd roller cam
