Old 09-28-2009, 01:35 PM   #25
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Default Re: Heads-Up Runs
Originally Posted by mopar jeff View Post
That does make more sense, so it's all about weight. I guess you would have to get creative in how you add that much to the car, since you can only have 100lbs. of ballast. Does 14HP really = 112lbs? That should be about 1/10th of a second too.
It depends on the class. A/SA is an 8 lbs per cubic inch class, and 14x8= 112 lbs. AA/SA is 7.5 lbs/in and it goes down in half lb increments for the most part.
Andrew Hill is online now   Reply With Quote
