Old 07-30-2009, 12:04 PM   #11
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Default Re: AHFS Question
3. For 2004, two runs by the same combination or the same class that are 1.15-second or quicker under the index during the evaluation period will trigger the AHFS process. With the change, two runs from the same driver or two different drivers would have to be posted to trigger the system and cause changes. This will help filter out "one-time fast runs" in categories where there are one or few numbers of a specific combination
This just means that the system is activated and a review will happen. It does not mean that a HP change WILL happen. It just means there will be a review of the combo. They then take all the other runs for that combo in consideration and the class average and then decide the proper course. If you run 1.40 under you WILL get 3.25% the next Monday. Jim
Jim Wahl is offline
