#1 | |
If I had your attitude, the following things would have never been tried or accomplished: 1.) Stop mufflers on SSers and Sers 2.) RA-IV stocker engine down to 356 from 380HP/375HP 3.) 1973 455SD from 350HP to 325HP (from a guy running nitrous on this combo) 4.) Edelbrock replacement heads on a few Super Stockers 5.) 1970 455HO reduced to 335HP from 360HP 6.) Delay boxes stopped from SSer and Sers 7.) RA-IV engine HP down from 380HP & 370HP down to 340HP in SSers. 8.) Indian Adventure block approved for Pontiacs in S and SS. 9.) Kaufman block approved for Pontiacs in S and SS. Nor would the following endeavors be tried: 1.) Correct statistical methods for AHFS 2.) Heads up races instead of 3 days of boring practice at Points races 3.) Edelbrock heads on stock Pontiacs to run against Edelbrock heads already existing on BBC's and 428 CJ motors. 4.) Edelbrock heads on 455SD motors and 421SD motors. 5.) RA-V heads for Modified engines 6.) A factory race engine heads up class at 6.0 and 7.0 for GT cars 7.) Factory Ram Air for Ram Air engines in GT cars. Ed, NHRA and IHRA has been very helpful if you keep after it and it makes common sense. You must keep the glass half full instead of half empty.......or better yet as engineers always say you gotta get the right size glass for the job! ![]() One thing I will bet you for sure......if we dont try it wont happen, and if it doesnt happen, it wont be because we didnt try.
Lynn A McCarty 3470 SS Last edited by Lynn A McCarty; 06-27-2009 at 01:50 PM. |
Bobby DiDomenico said, "And count me in on the WORST red light deal. I've been told the fans wouldn't understand it."
Do you know that a lot of faster guys go ahead and leave when the slower car goes red? No need to sit there on the trans brake for nothing, you have already won. A lot of the second red lights would never happen if the rules were changed.
Ed Wright 4156 SS/JA |
#3 | |
Liked 101 Times in 52 Posts
Now you are telling me that fine blinder thinga do doesn't actually prevent one driver from seeing the others tree? Even if you are correct, no reason BOTH drivers don't get the same chance to red light. Isn't it first or worst for the other infractions? And it wouldn't cost any money, its in the software. And Lynn, I've got this really big hammer, sorry I mean adjusting tool, to get the scoop to fit!! When are we doing it? Gotta come and see my aunt soon anyway. |
#4 | |
Some block the other side of the tree, some (smaller ones) don't. Many very good drivers don't use one at all. The slower car leaves first, right? If one doesn't do it first, they would go with worst. The slower car leaves first, so would go red first if the handicap is big enough. If they said "worst or first" it might be different. More often than not, I leave first. We seem to be run over with eight second hood scoop cars around here. Some of them only go red if I do. I asked one "If I go red, do you go ahead and leave?" He says "why not? No need to sit there getting my car hotter." Makes sense to me. My blinder does block the other side of the tree, so I never know if a slower car went red unless I look at the score board when the front end comes down. If I forget that, I find out when I get the time slip. ![]()
#5 | |
...And ,could you do me a favor? Look on DRC for the last time someone left 1-2 seconds early, after the first car red-lighted.
#6 | |
Liked 100 Times in 45 Posts
What i alluded to is that you will not change the make up of current NHRA race fans.They are a totally different breed now.If you can't see that this conversation is ended.Good luck and keep chasing those windmills. Ed
Former NHRA #1945 Former IHRA #1945 T/SA |
#7 | |
Lynn A McCarty 3470 SS Last edited by Lynn A McCarty; 06-27-2009 at 07:43 PM. |
#8 | |
The answer to your question: Obama??
Yes or Foolish whichever you wanna pick. Why do you think I have been promoting heads up instead of boring 3 days of practice? However if the silent majority stays silent, nothing will happen.
Lynn A McCarty 3470 SS |
#10 | |
S/SS.You will have the same 20 guys with deep pockets racing.Just like it was when the bracket format was introduced to raise participation levels.
