Old 06-04-2009, 08:08 PM   #1
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: Intermittent starting problem 70 challenger
get the volt meter out. start w if 12 volts to switch side of starter., check grounds next.
so it has nothing when hot/ no crank? check all connections for 12 volt from key to starter. voltage drop somewhere. If you were in NY, I'd check it out.
chris ok is offline   Reply With Quote
Old 06-05-2009, 06:04 PM   #2
Jeff Lee
Jeff Lee's Avatar
Fiat has a retro wiring harness available. Check the dealership in 3 weeks.
Jeff Lee 7494 D/S '70 AMX
Old 06-08-2009, 08:37 AM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Thank You Jeff........Problem is likely solved.......Just for fun I towed it up to Epping yesterday to keep me company playing in the Allstars.
It is likely the float, it does run rich, maybe got a bit of varnish from some old gas.
Car went 6 rounds, lost in the final on a .003 red....
Eric
Eric Merryfield 1883 STK
