Old 03-30-2009, 11:55 AM   #10
Charley Downing
Liked 633 Times in 88 Posts
Default Re: Overweight Stockers
At the Orlando pts the div 2 tech director ( Jim C) told racers that they must weight no more then the minimum for the next class up. Example if in you were running D/SA you could not weight more then the Minimum for E/SA with your combo. At the Gatornationls I went over the scales more then 150 pounds heavy and the div 2 tech director Jim C told me I would need to take 30 pounds out to make my car legal. After that run I went and talked to two of the national tech directors. They then told me that there was no such rule and I could run as heavy as I wanted to and not to worry about it.
Charley Downing is offline   Reply With Quote
