Old 03-27-2009, 07:31 PM   #1
Robert Swartz
Robert Swartz's Avatar
Default Re: Stocker suspension question
Originally Posted by herbjr View Post
I have talked to 3 people and got 3 different answers. Can I or can I not cut the floor to put the 2x3 Frame connector on a unibody. Thanks for the responses in advance.
Herb,
I'm going to assume you're referring to a stocker, right? I'm reading from the IHRA rulebook (because that's what's in front of me, not sure where the NHRA book is, lol).
It states: "Round tubing may be used to tie front and rear subframes together and join subframe in straight line extending through car floor, with floor completely welded to member." Keyword being MAY, meaning you can use round or box material. Says to me, you can run the material through the floor, just needs to be completely welded, so the floor of the vehicle is resealed.
This is how I intend to do my crate motor Firebird, when we tie the frames on it.
Robert Swartz
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
