#11 |
Liked 883 Times in 237 Posts
2X3X.083 " will be adaquate. ....The 01 body makes it easy since it's nearly a straight run to the rear rails. ....Only a short area of the floor needs to be sliced. ...You must weld the floor to the rail.......You can parallel the rear rail and just put an access hole thru it for the spring bolt. Tom
#12 |
Originally Posted by Dwight Southerland
Sub frame connectors are only legal when used with a roll bar or cage. Thank you Mark. I went back to the rulebook and couldn't find this. N/S and above are not required to have a bar or cage. With this implication, you couldn't tie the subframes of an N and up car. Does your V/SA Mustang have the frames tied? From the pictures, you don't have a bar in it. Robert Swartz
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
#13 | |
Yes, and so did the N/SA Omega before it. Teched in by Travis at Indy in '04
#14 |
Liked 7,783 Times in 1,743 Posts
Dwight, I can't find any place in the 2008 or 2009 rule book that says you can't have frame connectors without having a rollbar. Billy
#15 |
Tom, I'd bet there are less than 5 people on here that know what an 01 body is..... LOL.
Is that 67 a 232 2V ? AMXRON
none |
#16 |
Liked 8 Times in 7 Posts
#17 |
You might want to re-think that idea.
#18 |
#19 |
![]() Can you tell me anything good about that combination? I'm not seeing it.
#20 |
