Old 07-02-2008, 09:22 AM   #1
Smitty
Smitty's Avatar
Default Re: Colin Wigle
Originally Posted by stefan callender View Post
Youre right, because the Ford guys are smart, they never get hit and all the small block chevy guys are fighting it out with each other and getting hit every review. The 300-315 just got another 5hp
Stephen,
That all mighty 300/315 is actually facotred to 327 HP now. Damn, If I had a little more money I might be able to compete heads up with the 350 Camaro's that run in SS/HA and SS/IA. Now if they only do something with those 327's that are hauling a#$.
Smitty
Smitty is offline   Reply With Quote
Old 07-02-2008, 10:26 AM   #2
John Kelley
Originally Posted by Smitty View Post
Stephen,
Smitty
Don't work on your own combo !!
Get NHRA to factor the guys that do work hard on their cars...:-)
John Kelley is offline   Reply With Quote
Old 07-02-2008, 10:48 AM   #3
SSDiv6
Liked 1,583 Times in 582 Posts
John...Smitty did not say he did not work hard on his combo...he was talking about if he had more money to spend in the car. There is a big difference in the availability and cost of Chevy parts versus a Ford Cleveland engine.
Old 07-02-2008, 12:16 PM   #4
Smitty
Smitty's Avatar
Thumbs up Re: Colin Wigle
If I got my junk to perform anywhere near where the 327's and 350's perform my combo would be rated near 340hp just because it's a Ford. There are only a few cars running the Cleveland combo, tell me when you have seen any of them number 1 qualifier or better yet top 10. All of the engines avaliable for my car are rated at 305, 313, 324, and 330. I am already at a disadvantage weight wise because of the body style and then you tack on the HP difference between the Chevy's and the Ford's and it can be substantial. I will take what I can get, I am not taking anything from those guys who have them money and work hard to make their car's go fast but the field should be level. I will not hide my car or run from anyone, I will race within my means and if the guys got me covered by .6 tenths oh well.
My point is this, those combos are killer, they continulely dominate classes and the way the rules are set they should be factored, that is all I am saying. Thanks for the motivation however to work on my combo because that is what we plan to do.
Old 07-02-2008, 12:50 PM   #5
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
Smitty, those combos arent that killer, the reason they are fast is because there are so many of them out there and the combo has been running for 30 years. There arent alot of Fords out there compared to the Chevys. But if you took the two combinations and stacked them equally, the Ford should be rated higher.
Old 07-02-2008, 01:01 PM   #6
SSDiv6
Under what reasoning? When you compare the Chevy engine, with a lower deck block, lighter rotating assembly, better parts availability, the advantage is for the Chevy. Do not justify the Cleveland advantage on the cylinder head ports and valve size only.
