#1 | |
Liked 689 Times in 198 Posts
Not saying your +6hp was right or wrong but the comparison is off a bit.
Mike 7570 A/SA Last edited by Mike Gray; 11-16-2024 at 01:48 AM. |
Liked 1,832 Times in 415 Posts
Gary,
My position was not that the AHFS is perfect, it isn't. Nothing man made is. It probably should be "graduated" a bit, top to bottom. I doubt they'll take the time and make the effort. Nothing wrong with what you're doing, or how. I don't think anything in my post states that. Mike, Thanks for doing the math.
Alan Roehrich 212A G/S |
Liked 84 Times in 21 Posts
?IF? indexes are lowered will the association racer groups such as Midwest Class Racers follow suit? Or will they keep the door open for the folks that still desire racing their S/SS based cars that can?t make the ?new? indexes?
All those question marks in my post were not inserted by me. They automatically appeared???
Liked 334 Times in 185 Posts
Mike, it is currently 105, and I know Alan, just stating the reality I am dealing with and I am attempting hard to overcome and that it is not something that can be fairly dealt with top to bottom blanket equal index changes or reductions.
Flat stuck at the moment w/a Holley engine/sensor harness I am building from scratch to solve some of the issues, and hopefully there are solutions to finish it soon and workarounds that can be applied to make all the theory work to fit reality, even if not all features of the software are instantly available right away. If I can just adjust the fuel map, base and total timing, maybe get 2 step feature, and a few critical safeties (while removing the coded safety I suffer with most in the original stock logic module), some if not all of the data logging features, then I will be in a much better position and not be struggling as much. But, I have to have ignition to get off the launch pad, and that is where I am now In my wiring connection dilemma.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#6 | |
Mike 7570 A/SA |
Liked 902 Times in 192 Posts
Recent communication with SRAC says NHRA will NOT be lowering indexes. Carry on...
Bob Don 128 SS |
Liked 124 Times in 39 Posts
The site does not respect punctuation anymore. It throws question marks instead!
Sean Cour T6066 ladle |
If you post then go back to edit you can correct the punctuation marks.
Mike 7570 A/SA |
Guest
Posts: n/a
