Old 11-16-2024, 03:12 PM   #161
Doug Domm
Liked 84 Times in 21 Posts
Default Re: index lowering
All those question marks in my post were not inserted by me. They automatically appeared???
Doug Domm is offline   Reply With Quote
Old 11-17-2024, 12:42 PM   #162
Cglrcng
Cglrcng's Avatar
Liked 357 Times in 191 Posts
Mike, it is currently 105, and I know Alan, just stating the reality I am dealing with and I am attempting hard to overcome and that it is not something that can be fairly dealt with top to bottom blanket equal index changes or reductions.
Flat stuck at the moment w/a Holley engine/sensor harness I am building from scratch to solve some of the issues, and hopefully there are solutions to finish it soon and workarounds that can be applied to make all the theory work to fit reality, even if not all features of the software are instantly available right away.
If I can just adjust the fuel map, base and total timing, maybe get 2 step feature, and a few critical safeties (while removing the coded safety I suffer with most in the original stock logic module), some if not all of the data logging features, then I will be in a much better position and not be struggling as much.
But, I have to have ignition to get off the launch pad, and that is where I am now In my wiring connection dilemma.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 11-17-2024, 01:40 PM   #163
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
The site does not respect punctuation anymore. It throws question marks instead!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 11-17-2024, 01:56 PM   #164
Mike Gray
Mike Gray's Avatar
Liked 692 Times in 200 Posts
If you post then go back to edit you can correct the punctuation marks.
Mike 7570 A/SA
Old 11-17-2024, 02:00 PM   #165
Barry Polley
Guest
Posts: n/a
It?s a pain in the azz!
Old 11-17-2024, 02:11 PM   #166
Mike Gray
Mike Gray's Avatar
There is a reason I will forever be stuck in the '60s LOL
Mike 7570 A/SA
Old 12-23-2024, 09:39 AM   #167
Bob Don
Bob Don's Avatar
Liked 903 Times in 192 Posts
Recent communication with SRAC says NHRA will NOT be lowering indexes. Carry on...
Bob Don 128 SS
Old 12-23-2024, 09:46 AM   #168
JP1738
JP1738's Avatar
Liked 1,226 Times in 343 Posts
God is good
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 12-23-2024, 10:36 AM   #169
jmcarter
jmcarter's Avatar
Liked 3,195 Times in 976 Posts
Originally Posted by JP1738 View Post
God is good
….all the time.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
