Old 09-22-2021, 09:42 PM   #1
DeuceCoupe
Liked 48 Times in 44 Posts
And here's a little more. These are the class winners at the '71 Indy race.
The guy posting said he had to guess at some of the cars. Anyhow, it shows that Truman Fields won D/S, in his '68 Bird, & Arnie Toftland
won I/SA in a '71 Lemans.
NHRA Junior Stock
In '65, Leroy Stutzman picked right where Don Gay had left off in '64, winning the A/S class.
NHRA Junior Stock
I'm revisiting my Pontiac NHRA Factoring.
Making a chart of the 400cid and 455cid factoring (mostly 400cid)
re Arnie Toftland:
Do you know for sure it was a 71 LeMans?
I can get 2 cars to fit that I/SA=11.00 class:
71 LeMans hardtop 455/325 auto only (non-ram-air?)
3575/325=11.00
71 GTO convertible 455/335HO ram air
3717/335=11.10
It looks like Wheeler was the runner-up in I/SA=11.00 at 71 Indy, here's a picture, looks like a ram air convertible ie GTO:
https://archive.petersen.org/pages/p...php?ref=429361
But, are you sure which combo Arnie Toftland ran?
Old 09-22-2021, 10:37 PM   #2
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
re Arnie Toftland:
3575/325=11.00
3717/335=11.10
I don't have a clue. Lots of '71 racers used a 455HO T-37. Rock Running ran the 1st one I was aware of. Don Turk has it now. Scott Underhill held the E/SA nat record with his, a few years back.
The car in that pic is not a Pontiac. Looks like maybe an Olds. I suppose it could be a Buick. I'm not that familiar with either.
Just Googled it. A '71 Cutlass Supreme SX has the long scoops.
https://www.google.com/search?q=1971...X_enUS964US964
442 also has the long scoops, but looks to have deeply recessed grills.
https://www.google.com/search?q=1971...4n6noa2rjaNk1M
Old 09-23-2021, 05:24 PM   #3
DeuceCoupe
Thanks I dont know where I got Pontiac for the Wheeler car.
I thought that picture was a funny looking GTO.
The 1971 Indy narrative I have says I/SA=11.00
Toftland Pontiac win
Wheeler Olds R/U
No car years given.
From the picture & other info it looks like Wheeler is a
71 Olds 442 Convert, 455/340hp, W-25 OAI hood.
3744/340=11.01
For the winning Toftland Pontiac:
71 LeMans hardtop 455/325hp 3575/325=11.00 perfect fit to class
But the 455ho is a stronger engine, more underrated.
But to fit, the car has to be a heavy GTO Convert:
71 GTO Convert 455/335HO 3737/335=11.10
Without a picture or other info I'll just leave both of these guesses in.
Old 09-24-2021, 12:33 PM   #4
oldskool
oldskool's Avatar
Bruce Noland just ran a 10.591, with his '69 T/A, which is .809 under, & good enuff for #25 div 1 Q-1 list.
https://www.dragracecentral.com/DRCS...UMMIT#indextop
Chad Smith was #14, on that list, @ .832 under. He was driving a '77 Bird, which I think we have established use to belong to Paul Dilcher.
Name:	1 - '77 I-SA C. Smith .jpeg
ID:	60037   Click image for larger version
Name:	2 - Paul Dilcher .jpg
Old 09-24-2021, 06:53 PM   #5
oldskool
oldskool's Avatar
At the Midwest Nats, Julie Biermann ran an .872 under, 10.678, which was good enuff for the #26 position. Randi Lyn Shipp was #35.
https://www.dragracecentral.com/DRCS...er=30#indextop
Julie's 10.678 is a pretty respectable number. Don't know what her best time is, running in D/SA. Nowadays, you never know when/if a car is running all-out, or sandbaggin to protect their combo, by preventing an NHRA hp factor increase. No good reason to make your combo less competitive, just to see your name higher up on a Q-list.
She went 10.554 @ Indy 2020.
https://www.dragracecentral.com/DRCS...r2020#indextop
Don't know Randi Lyn's quickest time, in D/SA. But, she turned a 10.502, @ Indy 2019, which was 1.048 under. She's won at least 7 national events
https://www.dragracecentral.com/DRCS...r2019#indextop
They're 2 of the quickest D-port 1st gen Birds, ever. Mid 10's is quicker than similar Super Stockers ran back in the '70's.
Name:	1 - Rollin Left .jpg
ID:	60039   Click image for larger version
Name:	2 - Rollin Right .jpg
ID:	60040   Click image for larger version
Name:	3 - Indy 2020 .jpg
Name:	4 - Julie '21 Indy .jpg
ID:	60042   Click image for larger version
Name:	5 - Julie Biermann .jpg
ID:	60043   Click image for larger version
Name:	6 - Randi Lyn .jpg
Name:	7 - Randi Lyn Shipp .jpg
ID:	60045   Click image for larger version
Name:	8 - '20 US Nats .jpg
ID:	60046   Click image for larger version
Name:	9 - Randi .jpg
Old 09-24-2021, 11:00 PM   #6
Liked 5,153 Times in 1,967 Posts
I'm pretty sure you'll find that Tim /Julie's car is now a RA II
Old 09-24-2021, 11:27 PM   #7
oldskool
oldskool's Avatar
OK. Thanks for the info. I have no way of knowing that, since weight can be added/removed to move up or down a class. With @ 333hp D-port engine, it's a natural D/SA.
http://www.classracerinfo.com/Engine...9&MAKE=Pontiac
@ only 340hp, the round port engine Bird is also a natural D/SA. IMO, the round port heads & higher lift cam will MORE than make up that 7hp difference. So, if a racer don't mind running the rare & valuable round port heads, that seems like the smart way to go.
http://www.classracerinfo.com/Engine...3&MAKE=Pontiac
I remember that Leo Glasbrenner use to run C/SA with his round port '68. At least I THOUGHT it was round port. But hey, I could be wrong about that, too. I don't have any inside sources to keep up with what every Pontiac racer is running. So, most of the time, it's just a guess, on my part.
Also remember that Randi Lyn sometimes runs C/SA with her '67, which MUST run D-port heads.
Old 11-14-2021, 10:42 PM   #8
oldskool
oldskool's Avatar
"...But, are you sure which combo Arnie Toftland ran?.."
I think we covered this in another thread.
Arnie Toftland ran the "Viking" cars. One was a '70 GTO.
The other was apparently run as a '71 Bird, in H/SA. The pic I have of it & most every other '71 Bird Stocker I have a pic of, ran H/S or H/SA. BUT, as we've discovered, SOME years the class weight breaks were different, sometimes changing the class a car would run, from one season to the next. Also, it could have run a 400 engine, a D-port 455, or a 455HO round port engine. Therefore, it wouldn't surprise me a bit to find out this car also ran I/SA or G/SA, in certain years.
Name:	1 - Viking H-SA Formy  .jpg
Old 11-16-2021, 11:23 PM   #9
oldskool
oldskool's Avatar
Found a few pics in the last couple of days, which I don't think I've posted. Some are just different pics of cars I've mentioned earlier in the thread.
The 1st is another pic of the "Lil 2 Speed" '64 GTO.
Then there are a couple of '65's.
Pic 4 is one of the Royal '66 PR cars. I just posted it because I think it looks cool from the front.
#5 is a pic of the Nemesis '69 Judge I don't think I've posted.
#6 is a pic of the "Big Iron" '69 Judge, in the staging lanes.
#7 is the "Big Iron" '70 Judge, at the same track, plus another '70 Judge behind it.
#8 is a Grand Prix Stocker which I've never seen before.
#9 is another pic of the '60 "Big Iron", in the pits.
Name:	1 - '64 Lil 2 Speed .jpg
ID:	61281   Click image for larger version
Name:	2 - Roy's '65 .jpg
ID:	61282   Click image for larger version
Name:	3 - Bobcat B-S '65 .jpg
Name:	4 - Royal PR '66 .jpg
ID:	61284   Click image for larger version
Name:	5 - Nemesis Smoke .jpg
ID:	61285   Click image for larger version
Name:	6 - Big Iron .jpg
Name:	7 - 2 '70 Judges .jpg
ID:	61287   Click image for larger version
Name:	8 - Di Biase GP .jpg
ID:	61288   Click image for larger version
Name:	9 - '60 BIG in Pits .jpg
