Old 02-18-2014, 11:20 PM   #1
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile sbc stocker valve springs
Anyone willing to share what spring is being run on 305-350 engines. I try to get 200 closed and 400 open on our engines , but it's hard to get that much pressure without adding over .200 worth of shims. I've been running the 941 Comp springs but there too close to coil bind to suit me.Is there anything out there in a 1.260-1.290 spring that has around 200lbs@ 1.800 --400@1.400. Thanks for any replies. Bill
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 02-19-2014, 12:56 AM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: sbc stocker valve springs
Isky make a good spring. Made the change from K-Motion to Isky Tool Room and live increased 3x. 200 on the seat at 1.800 might not be achievable but if it needs that kind of seat pressure maybe look at some lighter valve train components within the rules of course. Lol
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 02-19-2014, 08:53 AM   #3
james schaechter
Liked 1,436 Times in 299 Posts
PAC 1409X beehive. They are the new version of the very good 1409. They just start out higher with the same spring rate. If you have not checked them out, they are worth a look. We beat the crap out of them and they are really good and durable.
James Schaechter 3163 STK
Old 02-19-2014, 01:12 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Yupp what James said.
Old 02-19-2014, 01:42 PM   #5
FED 387
Liked 333 Times in 180 Posts
get em cryod too
Old 02-19-2014, 08:36 PM   #6
tj310
http://www.speedwaymotors.com/search.html?query=915-760 decreased height locks---Trevor
Old 02-19-2014, 09:05 PM   #7
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Originally Posted by tj310 View Post
Not sure if I would feel confident using those locks on stout stocker springs,but that is just me.
Old 02-19-2014, 09:10 PM   #8
james schaechter
The nice thing about the beehive springs is that they are also lighter. PAC has the lightest design retainers as well. Light + Strong =Fun!
Old 02-19-2014, 10:22 PM   #9
derl
how about the 1218x pac beehive?
derl is offline   Reply With Quote
Old 02-19-2014, 11:35 PM   #10
james schaechter
I am sure the 1218x is a good spring for it's application. I have not tested it. I will say this. That spring has a lower closed pressure and a much lower spring rate. I would not use something that low in any of our stuff. Remember that some of the lowlift stuff like we run. 399 lift for example requires a cam lobe that is pretty square. The higher pressure is necessary to keep the lifter on thecam. Floating valves is a bad bad deal. There is no shortcut. You need to maximize your valvetrain to make power and also to prevent breakage. The 1409 and now 1409x is designed for the abuse we give them.
