#11 |
Liked 369 Times in 127 Posts
Thanks Tony.
Does the V-6 Mustang come with a 8.8 rear end ? Sounds like the combo needs 4.56 (or higher) gears, 28 inch tall slicks, high stall convertor, and drag springs. Would be great to get the car to run under the index with the factory 6 speed automatic.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#12 |
Liked 38 Times in 17 Posts
They do have an 8.8.
4.56 with a 4.17 first gear? Good luck! |
#13 |
![]() Is 4.17 the first gear ratio in the 6 spd auto ? If so, 1st shift at 7500 rpm should be at 30-32 mph with a 28 inch slick..
#14 |
Yes, this is why I had been running my 5.0 car with a 3.31 and 30" tire. Only uses 3 gears in a 1/4 and gets the overall ratio to something more manageable.
#15 |
Al,
Kdanner is wright you have to watch what gear you run, my current tire is 28' tall I will be trying a 3.55 and a 3.73 maybe a 4.10 gear with both a 28' and a 29.5 tire just to see what it will gain. there is a lot to the tunes on these cars but it is all positive stuff ,will let you know how I make out ! Tony K. |
#16 |
Liked 136 Times in 49 Posts
#17 | |
Liked 275 Times in 76 Posts
Sean
#18 |
Just more of the same. Ford sponsoring a race next year?
Ed Wright 4156 SS/JA |
#19 |
There are a lot of cars that are under rated at first ! but it does not matter for as the first guy that goes a second or more under things will start to change adjustments in HP rating, lower index etc. so with that said you have to be a fool to blast the index ! Me personally am happy with 4 to 8 tenths under. just my opinion and you know what they say about opinions !
Tony K. |
#20 | |
Liked 134 Times in 32 Posts
