#1 | |
Liked 175 Times in 78 Posts
2011 only had flat hood 2009-2010 had the scoop Ron
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
Liked 44 Times in 13 Posts
You are right there Ron.... But also the 09's and 10's had the v-8's and the 2011 had the V-10's... No V-8's in 2011.... Who knows... I have been told so many things since this started.... Guess we'll have to wait until Indy and just see.....
Mack Reeves 2377 STOCK & SUPER STOCK |
The 426 is a upgrade of the 2009-2010 to a 2011 is what I was told , but now I am confused as is others. It is entered as a 2009 - 426. We started it up today and everything seems good except the windows stoped working . I guess they are not 426 compatible. Now we have to get them working. Will they not work with 16 volt? I converted it from 12v to 16v and they stopped working.
The 426 sounds real good. Dan
Dan Wilson, STK3171, K/SA |
Liked 325 Times in 50 Posts
Your 426 is an 11.
Jeff Teuton 4022 STK |
Liked 2,354 Times in 554 Posts
The hood issue made them change - the combination could not be used in an 11 with a flat hood
09 + 10 hood works IMHO - Good after thought Ron
If you got a 426 Gen III from Arrow, either complete or unassembled, you will be rebadged as an 11. Originally it was to be a 13, but the final version was rebadged as a 11. The 426 has the new motor, scooped hood, and available 9 inch rear. All was to make a competitive shoot out car. The specs are almost identical to the 427 Copo motor. Now you have it.
#8 | |
It was somewhat related to the 12 to 16 conversion and manifested itself in mysterious ways - pretty sure the controller is "bunged" Check with them (Phil or Tony) 909-941-7800 to obtain one which works
#9 | |
Liked 61 Times in 26 Posts
Dennis Breeden |
#10 | |
Dan
