#51 |
Guest
Posts: n/a
If bigger diam lifters, bigger cam diam didn't work , SS,comp and Pro Stock would not have lifters over one inch diameter/ huge wheels and 70 plus?s mm cams. It is a performance advantage.
#52 | |
Liked 1,892 Times in 423 Posts
Trend.
Alan Roehrich 212A G/S |
#53 |
Liked 73 Times in 37 Posts
Yes, and if you can't increase cam core and/or lifter diameter, lofting the valvetrain reduces friction and adds hp, but some prefer keeping the lifter in constant contact with the lobe.
#54 |
Liked 734 Times in 385 Posts
In a thread on another forum they were talking about that many years ago Isky sold "Chilled Iron lifters". If someone today could manufacture these it might solve the problem.
Stan |
#55 |
The Isky chilled iron lifters are not harder than either the tool steel or the Johnson Hy-Lift hardened tappets. The only thing harder is carbide or ceramic.
#56 | |
Alan, That was talked about in the pages I posted. Stan |
#57 |
Liked 308 Times in 103 Posts
#58 |
Don't know, I was helping a guy do a freshen up on his combo, got the dial caliper out, told him the lifters were oversized, he said they are fine and to finish the build, so I did and never mentioned it again.
#59 |
I'm of the opinion that the tech department should put the OE lifter diameter rule in writing right now, and give everyone a year to comply, since it is a labor intensive and costly switch.
#60 |
Liked 231 Times in 107 Posts
Or Titanium
