Old 04-13-2021, 12:43 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Cool valves
I had replaced the ex valves and installed roller rockers . Now the valves are not turning. Any suggestions. thanks
Old 04-13-2021, 12:44 PM   #2
GTX JOHN
Default Re: valves
Valve Guide Clearance?
John Irving
741 Stock
741 Super Stock
Old 04-13-2021, 06:07 PM   #3
Jim Hanig
Default Re: valves
John i had ran these heads with the stock rockers , with the clearance .001 , put the roller rockers on while it was on the dyno , thats when it showed up.
Old 04-13-2021, 06:16 PM   #4
garyc
Liked 51 Times in 30 Posts
Default Re: valves
Rocker not square with valve tip?
garyc is offline   Reply With Quote
Old 04-14-2021, 11:49 AM   #5
SSDiv6
Default Re: valves
Valve geometry issue.
Old 04-15-2021, 11:27 AM   #6
Jim Hanig
Default Re: valves
and what would that be? i have the rocker in the correct location on the valve, and as i said these heads never had a problem until i put new valves and the comp rocker on them..
Old 04-15-2021, 12:23 PM   #7
SSDiv6
Default Re: valves
Jim,
Have you put some felt pen ink or die on the valve tip and done a full sweep to check the contact on the valve tip? A couple of guys I know have experienced issues with the Comp rockers because they are not the ratio they purchased.
Also, make sure sure the roller tip rotates free. Too many times I have seen others wash brand new roller rockers, removing the lubricant from the roller making them seize. A seized roller tip can generate a side load on the valve stem due to limited contact on the tip.
