#61 | |
Liked 16 Times in 11 Posts
Bob Pagano A/SA |
#62 |
They weren't 200-300 HP off though and that is the big difference. Let's face it, that would be like comparing a bogus DZ-302 Hp rating to a bogus '23 T-bucket HP rating. It is a 40 year technolgy difference. I'm all for the HP wars, but not at the expense of the older cars. A separate class is the answer and let them turn 'em loose on each other.
#63 | |
Liked 2,360 Times in 558 Posts
#64 | |
Liked 19 Times in 7 Posts
ss/gt 93 t-bird |
#65 | |
You are right in the sense that most combinations have been flogged very diligently by their owners, so pretty much every engine makes more than it's factor. However, everyone knows that a "Super Snake" makes 725 Hp with a smaller blower pulley and different tune. Other than those 2 items, the engine is the same as any other Shelby. I think you have misunderstood the meaning of the use of "bogus" when referring to the HP numbers. The late 60's & early 70's musclecars were SLIGHTLY underrated from the factory (say 35-50 HP) but the real intent was to get insurance companies to write a policy on these cars their owners could afford. I think the new cars are great for the sport but they need a little tweaking so as not to run out the older cars. I can't afford 80 G's for a new DP or CJ and I sure as hell don't want to drive 10-20 hours roundtrip and spend a few thousand only to be blasted in the first round by 6 car lengths over the course of a season. There are some people who always fall into the same bracket on the ladder. I would believe that you must own one of these new beasts and if you don't, please let me know your thoughts after a few "heads up" encounters. I doubt you'll be thrilled by losing by 5 cars to a guy who had an .850 light. |
#66 | |||
Currently, I run an LT1 Formula. We ran Top Stock at quite a few IHRA Division 9 events over the last few years (NHRA style). The racing was very close. I would love to see at least one FX class where these new cars can run heads-up. |
#67 | |
#68 |
Let's compare the 5.9L DP & the much maligned LT1 which share the same 275 hp factory rating.
The DP has: Ten more cubic inches. One full point compression, 11.57 vs 10.5. 2.02" vs 1.94" intake valves. 1.6" vs 1.5" ex valves. Much bigger, much higher flowing ports, before porting. 1000 cfm vs 750 cfm throttle body. Let me make those changes to my LT1 and you won't see me running any tens. You would have to be terrifically stupid to think there is anything right about this deal. You can't blame the guys for having them, but they should not be disappointed when the guys they beat in heads-up races aren't impressed with their performance, or respect their car building ability. It's a so-what deal. What if guys runs them heads-up a couple hundred lbs light? If you go across the scales 200 light you shouldn't get a hp hit, right? As long as they do get hit, right?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 10-14-2010 at 09:02 AM. Reason: Still can't spell... |
#69 | |
#70 |
Liked 279 Times in 68 Posts
A good stock eliminator motor will make about 1 and 1/2 times it's rated hp. If your motor only makes it's rated hp it probably won't run the index.
Greg Hill 4171 STK |
