Liked 9 Times in 8 Posts
Valve seats.....when installing new seats can you blend in the ridge in the casting at the bottom of the seat?
Is the Quick Fuel SSR-780-VS an acceptable replacement for the D0ZF 9310-Z Holley 4653? Can an adjuster be installed on the pushrod side of the rocker arm Can floor mounted clutch linkage be installed? Can the block be machined for 42/46 lifter phasing? Thanks |
#2 | |
The way I read the rules the carb is the same size so should be ok. One more question.... Is a carb spacer legal? |
Liked 204 Times in 54 Posts
Stock or Super Stock?
stock
No clutch on the floor stock or SS ---Trevor
Liked 112 Times in 31 Posts
Bill,
Valve seats? Technically - No. Actually it depends on how they're installed and the valve job finished. Some ways are legal, some aren't, but these days almost anything passes I guess. Quick Fuel Carb? YES it is legal, but the secondary idle screws must be removed and the circut blocked. Pushrod side adjusters? Why? Roller rockers are allowed now. Floor mounted clutch? NO! Lifter bore mods? NO, but I'd like to see them check it. Carb spacer? NO. You can only use two factory type gaskets. I think all that is correct. If not, I'm sure someone will help out. Jerry |
#7 | |
the 42/46 lifter angle matches the heads better than inline lifters...the valvetrain geo isn't even close to where it needs to be, its the only way to get these canted valve motors to run up top....I don't see where it says I can't do it Last edited by Bill Diehl; 12-14-2013 at 11:56 PM. |
