Old 12-22-2019, 10:46 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default keep working on your stuff
so after the last race of the season on the east coast (dutch classic ) i again had been out gunned in my class yeah ,my combo doesn't run bad and could content with leaving alone ( no I am not bitching or complaining) after that race i immediately pulled the motor out to find more ,look at the chassis for a better 60' searching for some horse power in the engine ,move or remove weight ,yeah some combos are stacked more than others and you pick your combo and make the best of it ,rule changes can have a impact on how fast you can go with what the rule book allows to run at the given time ,i am the owner,crew chief,mechanic,engine builder ,oh as most have a job that gets in the way of my racing , but i always in search of the last bit of horsepower that i can find with in the rules,but the point is of this post is that every time the motor is out i always find things that can be improved ,what is working and what's falling apart and that's the part where you can push the envelope further (or not)
even if your not the wrenches working on your car keep thinking out side the box on ways to improve your combo with the wrench hand ,,
no its not cheap but there are guys/gals out there running fast with minimal financial backing, resources and are not afraid to keep changing things to get the most out of there combo
this class is for people who are looking to go fastest with in the rules in place
keep working on YOUR STUFF
merry Christmas
Gmonde
Old 12-22-2019, 11:20 PM   #2
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
Default Re: keep working on your stuff
As always, I'm curious.
So, are there some in Stock who know they'll never have the money to get their car more than .500 under, who are content to make the car cut good lights & run consistent ET's, in order to continue running in Stock, at races where all run ?
Are there those who have the same car they've had for a LONG time, which is a bad combination, therefore will never be really competitive in a heads-up run, but they wanna keep running that same car/combo ?
Are there some who do a not have a quick heads-up car, but it cuts good lights, runs consistent ET's, & is also used for bracket racing, when not entered in a class race ?
OR, do most other class racers look down their nose at all who use their car for bracket racing also ?
OR, is class racing made up of some of all these types of racers ?
Old 12-23-2019, 07:24 AM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 983 Times in 314 Posts
Yes to all those questions............
Old 12-23-2019, 08:13 AM   #4
richie 2
Liked 205 Times in 93 Posts
just trying to get everything togeather...some day it will...
Old 12-23-2019, 09:29 AM   #5
Liked 11,032 Times in 2,267 Posts
I work on my continuing education everyday trying to solve my physics problem with shinny wheels.
Old 12-23-2019, 10:57 AM   #6
HawkBrosMav
Liked 302 Times in 73 Posts
So, are there some in Stock who know they'll never have the money to get their car more than .500 under, who are content to make the car cut good lights & run consistent ET's, in order to continue running in Stock, at races where all run ? When we built the car yep.. still on a tighter budget but can go a little faster the .500 under 10 years later...
Are there those who have the same car they've had for a LONG time, which is a bad combination, therefore will never be really competitive in a heads-up run, but they wanna keep running that same car/combo ?10 years.. but I feel new to this game.. Will always be a for and this combo was the cheapest for the parts we had lying around to get a car running.. I would say it's not a great combo but it for sure ain't bad
Are there some who do a not have a quick heads-up car, but it cuts good lights, runs consistent ET's, & is also used for bracket racing, when not entered in a class race ? Absolutely... car makes 10 times more passes a year in bracket races than Stock..
OR, do most other class racers look down their nose at all who use their car for bracket racing also ? this one is pathetic but I know it happens
My guess would be a little of everything.
Old 12-23-2019, 10:20 AM   #7
fredjohnston
Liked 55 Times in 14 Posts
merry Christmas
Gmonde
Nice post but not applicable to the real world. I'll use SS for an example: take the tried an true 350/300 hp chevy. This combo most likely falls into SS/GA or HA or even into a GT combo. Do you really think this engine is going to run close to or even outrun an injected Firebird in SS or an injected 350 combo in GT You can "keep working on your stuff" all you want, but with the current HP factor you'll never get close. This is
where the AHFS doesn't work and NHRA needs to step up to the plate.
fredjohnston is offline   Reply With Quote
Old 12-23-2019, 11:29 AM   #8
jmcarter
jmcarter's Avatar
Liked 3,252 Times in 989 Posts
oldsckool, in answer to your question “ OR, is class racing made up of some of all these types of racers ?” the answer is a definite yes. Many don’t have the resources to run the higher class cars and their old iron does just fine in the lower classes since in most cases they are not pitted against newer technologies in heads up runs. Whenever AHFS catches up with new combos there will always be a newer faster equally underfactored magic carpet (which NHRA will always approve to keep the class “relatable” to new fans) and some can simply shell out the 50-100K to upgrade. If/when NHRA runs most of us off and regional class associations start seeing more heads up runs they will have to come to grips with that unlevel playing field. I can think of several ways to achieve that but there will never be complete agreement on how to do that. Simplistically you could require dials on heads up runs by cars with new/old platforms but that would be a firestorm. Not solving world hunger here, just a simple means to run mismatched combinations that wouldn’t run off people in the process. Love the heads up runs, if they don’t get your adrenaline pumping you’re in the wrong place but if I’m running a B/SA Barracuda against a 2015 Camaro VIN car then the fun has just been siphoned off by a bogus HP rating which your local association had no part in approving.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-23-2019, 08:53 PM   #9
gmonde
gmonde's Avatar
I agree ,, but its nhra's sand box and you can choose what you want to run or not run .the cars in my class ranged from 68-70 including my car
yeah the fuel injected cars have a leg up , i have the option of going to a ss/GT class and run the gen3 hemi ,, yes it will have fuel injection
Old 12-23-2019, 11:31 PM   #10
cmracing
Liked 62 Times in 29 Posts
Which combo would you rather have in the heat of the summer in a B/SA Stocker: A 396 BBC or an LT1 SBC............
cmracing is offline   Reply With Quote
