Old 05-16-2011, 12:23 PM   #1
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Default Minimum and maximum weight for Stk and S/S
Wording in the 2011 NHRA rulebook for Stock and all classes in Super Stock Eliminator concerning WEIGHT reads as follows:
“All cars will be permitted to run on the class minimum weight, but may be no heavier than the minimum for the next heavier class.”
We have been instructed in tech to put both the minimum and maximum weight on the weight sticker that goes on the car. The maximum weight is figured by taking the minimum weight for the next heavier class and subtracting 5 pounds.
At the scales the maximum weight is enforced the same as the minimum weight…too heavy or too light is a DQ.
Travis Miller
(Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.)
Travis Miller is offline   Reply With Quote
Old 05-16-2011, 12:27 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Minimum and maximum weight for Stk and S/S
Travis Miller
Sounds great! Thanks Travis!
Ed Wright 4156 SS/JA
Old 05-16-2011, 01:47 PM   #3
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Travis,
Thank you for the insight. I was woundering how that rule was going to be enforced.
Larry
Larry Curtis is offline   Reply With Quote
Old 05-16-2011, 02:35 PM   #4
Jeff Lee
Jeff Lee's Avatar
Great move!
Jeff Lee 7494 D/S '70 AMX
Old 05-16-2011, 03:10 PM   #5
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Gives new meaning to the saying "get the lead out".
Former NHRA #1945
Former IHRA #1945
T/SA
Old 05-16-2011, 04:55 PM   #6
Jeff Teuton
Liked 325 Times in 50 Posts
And all this time I thought the officials were just admiring my car. I guess I should have noticed the admiration was always from the weight sticker side.
Jeff Teuton 4022 STK
Old 05-16-2011, 10:08 PM   #7
Pvt Parts
Pvt Parts's Avatar
Travis Miller
Travis,
So are you going to DQ someone for weighing 3 pounds under the maximum weight as it's defined in the rule book?? “All cars will be permitted to run on the class minimum weight, but may be no heavier than the minimum for the next heavier class.” If that's the rule it doesn't say anything about 5 pounds under the minimum.
Old 05-16-2011, 11:20 PM   #8
Travis Miller
Originally Posted by Pvt Parts View Post
Travis,
The reason 5 pounds is used is because the scales read in 5 pound increments, not 3 pound increments. The maximum weight limit works just like the minimum weight limit. The rule has always been if you are too light it is a DQ. Now with the new rule if you are too heavy it is also a DQ.
Travis Miller
Old 05-16-2011, 11:59 PM   #9
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Travis, glad to hear the news. I was beginning to think that every ruling was going to favor the factory cars.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-17-2011, 02:14 AM   #10
Toby Lang
Liked 2 Times in 1 Post
Travis Miller
Well, if my minimum for the next heavier class is 3500 pounds and I get on the scale and I weigh 3500, I am not heavier than the minimum for the next heavier class, correct?
You either need to change the rule to say you must weigh less than the next heavier class or allow people to weigh right on the minimum of the next heavier class.
-Toby
