Old 10-22-2009, 08:38 AM   #1
Stocker 2
Default Pulley size is now a spec
Check it out, pulley sizes are now part of the specs on the supercharged Mustangs.
http://www.nhra.net/tech_specs/engine/blueprints/FORD-08.rtf
Stocker 2 is offline   Reply With Quote
Old 10-22-2009, 10:26 AM   #2
BlueOval Ralph
Banned
Default Re: Pulley size is now a spec
More important what DIA HAVE THEY BEEN RUNING AND WHAT DIA WERE THE RECORDS SET WITH GONE THRU TECH WITH?? LOOKS TO ME AS NHRA BOY'S DROPPED THE BALL BIG TIME N THIS ONE. The 57 fords had their dia llisted and as I remeber the Stick Shift was different than Auto had more Boost.
http://www.nhra.net/tech_specs/engin...ts/FORD-08.rtf
BlueOval Ralph is offline   Reply With Quote
Old 10-22-2009, 11:13 AM   #3
Bill Grubbs
Liked 573 Times in 67 Posts
Also important to note is OEM pulley's only! No aftermarket! No playing with Belt and groove widths.
Bill
Bill Grubbs is offline   Reply With Quote
Old 10-22-2009, 11:58 AM   #4
Chad Rhodes
Bill
exactly right Bill, it should also state that the tensioners must be OEM as well
Chad Rhodes 2113 I/SA
Old 10-23-2009, 07:50 AM   #5
Tim Kish
Liked 11 Times in 4 Posts
Why should the tensioner have to be OEM?
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 10-23-2009, 09:46 AM   #6
Chad Rhodes
the OEM tensioner is spring loaded. Metco and others make tensioners that are positive acting, and act on a different place on the belt thus increasing boost by eliminating any slippage. The tensioner should at minimum have to be of OEM type (spring loaded) and should be in the stock location
