Liked 9 Times in 8 Posts
Hey Guys,
I am looking for welding tips and bracing of axle tubes for factory 12 bolt housing - where tubes join the pumpkin and as fully assembled or Probably has to be completely disassembled? Thanks, Craig |
Liked 1,985 Times in 598 Posts
Find a good welder and have the tubes welded to the center section all the way around. Bracing can be accomplished with a LPW cover with the bracing option.
Mike Pearson 2485 SS |
What successes or limits have others had with a Tubes Welded Ladder bar 12 bolt = limits of factory Tubes strength?
Thanks, Craig Last edited by CraigG; 07-21-2025 at 05:28 PM. Reason: needed |
Liked 7,898 Times in 1,754 Posts
Unless you're not putting a lot of power through this 12 bolt, I wouldn't use a stock housing. This is from my own personal experience. The axle tubes won't handle lots of power.
Thank you - I will probably get the welding of the tubes and the LWP cover with the brace.
Liked 11,007 Times in 2,263 Posts
Keep an eye on pinion angel if it changes the tubes are twisting.
Tubes that are welded to the center section shouldn't twist BUT the stock tubes will tear either at the weld or at the spring mounting point.
You can probably get good money for the factory 12-Bolt case. Maybe enough to buy a new aftermarket one that won't have the issues that the stock one will.
Daren Poole-Adams NHRA Stock/SS 2007 |
Liked 130 Times in 42 Posts
Go aftermarket, thicker casting and tubes, weld them all the way around and brace it like I did and you'll never worry about it again.
Don't think ladder bars will go on there real easy...;-)
