Old 03-17-2025, 07:14 AM   #1
Bob F
Liked 16 Times in 11 Posts
Default Front end height question
Going to install a pair of Landrum springs.
If the ride height is too high do I cut them or exchange them for a lighter pair?
Bob F is online now   Reply With Quote
Old 03-17-2025, 08:52 AM   #2
Ralph A Powell
Liked 227 Times in 138 Posts
Default Re: Front end height question
I would exchange if you can!
Old 03-17-2025, 06:22 PM   #3
SDT1DYI
Liked 456 Times in 148 Posts
Don't cut them. Let the car settle on the new springs. Best to get the car on 4 scales and see what the corner weights are, with and with out a driver Check RR for Preload..
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 03-17-2025, 08:24 PM   #4
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
From one rate to the next, it will change the ride height about 2 1/4 to 2 1/2 inches. It?s not an exact figure, but it?s a good ballpark to go off of. If you need the car to set less than 2 inches from where it is now, you will either shim it or trim a small amount off of the spring. Depending if it?s too high or too low.
It usually settles very little. But they will settle a little bit.
If you have any questions, feel free to call me
717-793-6819.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 03-17-2025, 10:11 PM   #5
CMcAllister
Liked 930 Times in 264 Posts
In my experience, a Landrum will settle a little bit then be good. The other spring people use will settle through the life of the spring and need replaced eventually.
I will trim a spring, but not much. 1/2 a coil maybe. Even trim a bit more on one side if needed. Trimming the spring changes the rate.
Old 03-19-2025, 11:14 PM   #6
Mike Merk
Mike Merk's Avatar
Liked 117 Times in 31 Posts
If you trim coil springs, a very accurate rule of thumb is that for every inch you want to reduce ride height, cut half an inch of spring height. For a 2" ride height reduction, cut 1" of coil spring height off.
Mike Merk
Mike Merk is offline   Reply With Quote
Old 03-20-2025, 08:24 AM   #7
Marty Rinehart Jr
Yes,
that?s another rule of thumb to go on.
Thank for bringing that up
Marty Rinehart Jr
Old 03-20-2025, 01:46 PM   #8
Jeff Niceswanger
Liked 1,071 Times in 378 Posts
Marty, One of the pains was every other year replacement of the front spring on the F-Body. I wondered if this was still down in the box, so I just walked down and looked. Here's my old templet for the Moroso 210s in that car of Hunztberrys. With the Morosos, on this car, I found you could cut...not much movement. Cut the same amount.... not nearly enough. Another inch, same thing. Simply cut that same amount and the car drops 2 solid inches! You just ruined a set of springs. For that reason, I kept a templet. If I would have kept it, this was going to be on the to do list. Landrums ....
Name:	Moroso Spring Small.JPG
Jeff Niceswanger 3740 SS
Old 03-22-2025, 08:30 PM   #9
Bob F
I?ll be starting with a pair of 200?s to replace the cut old Moroso spring that are almost on the bump stops.
Old 03-24-2025, 03:45 AM   #10
Greg Barsamian
Liked 427 Times in 97 Posts
What make, model & engine size is your car?
