Old 01-22-2024, 05:30 PM   #1
sean1970ss
Liked 10 Times in 6 Posts
Default Flywheels has little bit of glaze from clutch disc went bad
Had a clutch disc go bad it made some glaze on the flywheel nothing bad. Would it be alright to use some sand paper to knock it off? orbital sander?
Also with a diaphram set up how much clearance between the throw-out bearing and fingers? 1/4?
sean1970ss is offline   Reply With Quote
