Old 11-05-2023, 08:27 AM   #1
ron b
Liked 4 Times in 4 Posts
Default 8.8 ford ring and pinion cryogenic treatment
i need a new gear in a 8.8 rear end. thinking about going the cryogenic route. is it and the rem finish worth anything for longevity? thanks ron b
ron b is offline   Reply With Quote
Old 11-05-2023, 01:37 PM   #2
Dirk Olson
Liked 172 Times in 46 Posts
Default Re: 8.8 ford ring and pinion cryogenic treatment
Absolutely moves the grain structure in the metal making stronger and less prone to fatigue. Call Wanye @ Indy Gear he can help you out.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 11-08-2023, 11:38 AM   #3
ron b
i would like to find a place that does both the cyro and rem finishing.
Old 11-08-2023, 07:12 PM   #4
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Earp Machinery, 928-792-3835 they can do both. Talk with Terry.
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 11-08-2023, 07:18 PM   #5
SSDiv6
Liked 1,580 Times in 582 Posts
https://www.performancemetal.net/
https://pemracing.com/
Old 11-11-2023, 08:51 AM   #6
Coleydog
Liked 53 Times in 38 Posts
Is the cryo treatment the same as the old way of dropping the gears in dry ice solution for 24 hours?
Old 11-13-2023, 11:22 PM   #7
Shadylane
Shadylane's Avatar
Here is some information on the process.
https://www.crownracegears.com/cryogenics.html
Kelly Lane Stk4991
Old 11-14-2023, 02:17 AM   #8
David Lee
Liked 346 Times in 126 Posts
you would need to do it in liquid nitrogen
Old 11-15-2023, 07:51 PM   #9
Coleydog
Dry ice is frozen co2 that’s cold
Old 11-16-2023, 12:49 AM   #10
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Liquid nitrogen (-320*F) is far colder than dry ice (-109*F)
Dave Noll, EF/S ,?/SA 6526
