Old 12-15-2022, 08:24 AM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default 94 inch circumference Hoosier tires.
Anybody ever switched from 94 inch rollout to 92 inch tires rear tires? How much rpm change did you notice? Was it a good change or bad change. Any et change? My combo is LT1.
Kdw1403 is offline   Reply With Quote
Old 12-15-2022, 09:33 AM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: 94 inch circumference Hoosier tires.
I do occasionally, 92.5" to 94" Hoosiers. About 150 RPM higher with the shorter tires.
Jim Kaekel 3836 STK
Old 12-15-2022, 11:04 AM   #3
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Just looking to see how close theory comes to actual measured results.
► 9250 RPM * (94 / 92.5) = 9400 RPM
Stan
Old 12-15-2022, 01:42 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
I have a LT1 car. When I originally built it I thought I wanted the biggest tire I could fit. So I put the 94” on it. I’ve since been told I should have the 92.5” with my 4.88 rear gear. So I’m switching.
Old 12-15-2022, 07:29 PM   #5
MR DERBY CITY
Liked 7,941 Times in 1,520 Posts
Kdw, I am sure that the majority of class racers have tried both the 92 and 94 inch tires. The rpm difference will be 150-200 …As far as ET , there are so many variables from car to car…..is your first gear a 2.52,2.75,2.85,2.91 ??? The same holds true for rear end gear …Weight of car could also determine what tire it likes. It’s something you just have to try at the track …
Old 12-16-2022, 12:11 PM   #6
ss125h
Liked 80 Times in 28 Posts
have changed 92" to 94" many times, on two stockers, I and J auto, adds up to 200 rpm in the traps with 4.86 gear. Glen H 1257
ss125h is offline   Reply With Quote
Old 12-17-2022, 08:46 PM   #7
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Hoosier Rep told me a rule of thumb is 100 rpm for every
Inch of roll out. So 92 - 94 2 inch difference 200 rpm
Looks like from the other posts he was correct
Willyracer is offline   Reply With Quote
