Old 06-12-2022, 09:26 AM   #1
hrs1326
Liked 19 Times in 10 Posts
Default Edlebrock 60917 NHRA head
Can someone enlighten me on these heads? It seems the exhaust ports are re-positioned from stock?? Exhaust flanges shortened???
Using these on a Super Stocker and they are causing some real grief.
hrs1326 is online now   Reply With Quote
Old 06-13-2022, 10:18 AM   #2
Charles Stewart
Liked 753 Times in 213 Posts
Default Re: Edlebrock 60917 NHRA head
From the Edelbrock technical instructions:
Exhaust flange has been extended out .125” in order to provide dry exhaust bolt/stud holes.
From NHRA classification, they carry a penalty (weight/ratio HP) for using those heads.
https://edelbrock-instructions-v1.s3...rock/60917.pdf
Charles Stewart is offline   Reply With Quote
Old 06-13-2022, 02:13 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,931 Times in 580 Posts
You can bet that anyone running those heads in SS has that extra flange milled off the exhaust ports
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 06-17-2022, 09:01 PM   #4
Tom Broome
Liked 88 Times in 43 Posts
I expect what Mike is saying is....Yes, fully prepared (ported/welded/etc.) SuperStock heads, regardless of origin, probably have had the exhaust ports relocated somewhat, and had the flanges cut down for port volume reasons. Without seeing what you're working with, I'd anticipate that exhaust flange adapters, properly matched to the port center-lines are going to be necessary.
Tom Broome is offline   Reply With Quote
Old 07-11-2022, 02:08 PM   #5
Liked 10,714 Times in 2,230 Posts
If anyone has a set or two to sell I am very interested. Thanks
