Liked 20 Times in 12 Posts
What does everyone like for wheelie bars on their leaf spring cars? I haven’t had much luck with a set from Calvert. It seems like as soon as the bars hit it wants to push the back of the car up and unload the rear tire. This is a Camaro on split mono leaves with a Ford 9” rear.
Liked 685 Times in 204 Posts
You need a good set of front shocks to control the rate and height of the front end.
Liked 10,731 Times in 2,233 Posts
May want to consider raising the the bars up a little at a time until the 60’ slow down. Just a thought.
Liked 239 Times in 114 Posts
I like a set with some springs on them to give a little cushion when they hit the surface. Competition Engineering has a decent set that I use on my 1973 Formula with leaf springs.
#5 | |
Larry, I'm out of upward adjustment on the bars at about 3.5" between the bottom of the rear wheel and the ground. I've even gone so far as to cut the bars apart and fabricate new attachment points to gain a little more clearance, but I'm maxed out. Seems like a lot of folks set theirs much higher in this type of application. |
Liked 574 Times in 212 Posts
Move weight forward, a little at a time and firm up the rear shocks.
Gary Hansen - SS/FA 4911, B/SA 4911 |
Liked 319 Times in 82 Posts
Ken Kier single
Was in contact with the folks at Ken's shop today. Waiting on a call back, and hopefully we can make something happen there. There is a picture or two on their Facebook of the bars installed on a drop-out center section housing that looks like it would work for me. I don't expect any one part to be the miracle cure-all, but if changing the bars would help make an improvement, I'm all for it.
Just to put a period on this, I ended up with a set of bars from Ken Keir. These things are a work of art, but more importantly, the customer service was outstanding. Both Ken and Ronnie Johnson patiently answered all the questions I had, and made me feel as if I was their only customer. I would highly recommend to anyone needing these types of products or services.
