Old 03-08-2022, 06:10 PM   #1
gmrocket
Default What Stocker class for 73 Olds Omega?
Anyone know what class and what the class is running and the record?
Same body as the Nova but would the Olds 350/160 HP 4brl for that year
gmrocket is offline   Reply With Quote
Old 03-08-2022, 06:55 PM   #2
Billy Nees
Liked 7,773 Times in 1,742 Posts
Default Re: What Stocker class for 73 Olds Omega?
www.classracerinfo.com
Billy Nees 1188 STK, SS
Old 03-08-2022, 07:14 PM   #3
gmrocket
Ya i found that...where do i find what the current factored hp is?
Old 03-08-2022, 07:55 PM   #4
Rory McNeil
Liked 1,104 Times in 302 Posts
The factored HP numbers are at the bottom of columns that show the power to weight ratios for each car model and engine combo.
NHRA 6390 STK
M/S 85 Mustang
Old 03-08-2022, 10:06 PM   #5
Let's cut to the chase here...HP too high.
If you have the desire to race a 350 Olds engine, find yourself a 77 Firebird.
You're welcome ;-)
Old 03-09-2022, 09:42 AM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
Buck Jednak, Ron Garey and Al Provoast had some pretty quick Olds-powered Omegas back in the day and that's probably how the HP got up where it's at. However, if you've got the will and the way...you could just build it and get it on the track. Then e-mail NHRA to get the horsepower reduced. They rarely reduce HP if there's no current data to support it. Just my .02.
Jim Kaekel 3836 STK
Old 03-09-2022, 10:35 AM   #7
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
It's NHRA rated at 240hp/14lbs per HP=3530lbs including driver.
Not a bad HP factor. The same year Chevy is factored to 287hp for reference and the Buick Apollo seems to be a good combo too and the Pontiac Ventura of the same year seems like decent combos too. Not too familiar with the Olds engines power potential but I'd seek out Provoast or whoever did his engines.
Old 03-09-2022, 10:53 AM   #8
Billy Nees
'73 Olds 350 with a 4V is at 285! IMHO, the 350 Olds is every bit as good as a 350 Chevy but expensive. The 77 Olds 350 in a Firebird is rated at 250 HP.
Old 03-09-2022, 01:24 PM   #9
rboyle
rboyle's Avatar
But he is specifically asking about the 1973 Omega with factory rating of 160hp, which NHRA has rated at 240Hp, not 280 or 1977 rating. He has a car already apparently.
Old 03-09-2022, 02:20 PM   #10
Yes, but you compared it to other GM 4 bbl 350's .
If you want a fair comparison, try the 70 350 Chevy... 1.375 carb @ 224 HP in a Nova.
Olds has the 1.18 carb..Same as a 305... Still not a good combo.
Just because someone has a car in his possession, it doesn't mean they ought to build a
non-competitive Stocker out of it ... It's a false economic situation, in the long run.
