Old 08-03-2021, 04:11 PM   #1
tolaas
Default which radiator
Hello, i have a 67 camaro stocker, and going to bye a aluminium radiator, so...i think of a direct fit with a fan. Are there any brand who are better then others? And can i use a two row radiator if i have a small block engine?
Torbjorn Laas Sweden
tolaas is offline   Reply With Quote
Old 08-03-2021, 04:57 PM   #2
Liked 11,032 Times in 2,267 Posts
Default Re: which radiator
Use the one that is the lightest when full of water.
Old 08-03-2021, 07:13 PM   #3
Painter
Liked 162 Times in 45 Posts
I went to the local chain parts store and ordered a replacement radiator for a six cylinder for my year. Single core aluminum with plastic tanks. About a hundred bucks. Perfect fit. Car runs as cool as it did with the factory radiator and I lost five pounds off the front of the car. Ow if I could get the driver to lose a few pounds!
Painter is offline   Reply With Quote
Old 08-05-2021, 01:23 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 889 Times in 239 Posts
For a Stocker , Id use a 2 row from Champion Radiators.
They have a direct fit model .
Old 08-05-2021, 03:44 PM   #5
tolaas
Thank you for your answers, Painter, which year do you have on your car?So you don`t have any heating problems?
Old 08-05-2021, 04:19 PM   #6
Painter
My car was an original 1970 6 cylinder automatic. So that’s what I ordered. Perfect fit and I think the car runs cooler!
Old 08-05-2021, 05:14 PM   #7
tolaas
What brand is it? I didn`t found any plastic radiators on summit.If your car is a 1970 maybe i can find to my 67. Du you have any electric fan on the radiator?
Old 08-05-2021, 07:29 PM   #8
BillK
Liked 30 Times in 17 Posts
tolass,
I had a 67 that I bracket raced for years. I am not sure what you guys are allowed to do as far as modifications but somewhere along the line I installed a radiator out of around an 85 Camaro. Aluminum radiator with plastic tanks with the attached shroud / electric fan combination. It was very light and worked fine cooling an approx 550 hp small block. I had to do a slight modification to the core support because it was a little wider than the stock radiator but it was nothing major.
Bill Koustenis
BillK is offline   Reply With Quote
