Old 06-09-2021, 09:22 PM   #1
Greg Gay
Liked 286 Times in 73 Posts
Default Rear Sway Bars
Evan Smith wrote a really nice article in National Dragster about sway bars, but are there other ways to make a car do the same thing. Weight preload, shock settings, shortening the passenger side upper bar on a 4 link, spring rates. Or, are each of these items doing something different than the sway bar accomplishes. One time, my Super Bee was picking up the left rear quarter a considerable amount, but the right rear was doing nothing. I had all of the clamps off the right, but no lift. Finally, I started clamping the left, just to calm it down. It did, but it also started lifting the right. I had no idea that the torque would transfer to the other side of the car. Last question in all of this: Is a sway bar even an allowable addition to a Stock Eliminator car?
Greg
Greg Gay is offline   Reply With Quote
Old 06-10-2021, 12:26 AM   #2
GTX JOHN
Default Re: Rear Sway Bars
I have seen them on cars that never came with them.
I even saw at Indy a few year ago an A Body Mopar
with the front sway bar installed on the rear axle!
I discussed it with the gentleman
and he said the rule did not say where sway bar could be placed
John Irving
741 Stock
741 Super Stock
Old 06-10-2021, 07:43 AM   #3
Ralph A Powell
Liked 227 Times in 138 Posts
Great point but it also did not say he could move to rear! That’s what the Tech guys answer would be.
Old 06-10-2021, 09:04 AM   #4
garyc
Liked 51 Times in 30 Posts
yes I read article also, building 1975 mopar b body M/AS was going to leave factory rear bar and make adjustable links
garyc is offline   Reply With Quote
Old 06-10-2021, 09:15 AM   #5
Billy Nees
Liked 7,909 Times in 1,754 Posts
Brakes & Suspension:3
Suspension, Rear
"Sway bar(s) optional"
I seem to remember that a couple of years ago the Tech Dept. came out with some kind of a ruling that a "sway bar" or an "anti-roll bar" from the aftermarket couldn't be "welded in" but had to be "bolted in" a Stocker.
Billy Nees 1188 STK, SS
Old 06-10-2021, 09:36 AM   #6
garyc
I always interpreted it as you can remove factory bar
Old 06-10-2021, 10:21 AM   #7
Billy Nees
I think this came about because someone put an aftermarket type "anti-rollbar" in a 3rd gen F-body (welded in) and posted pics of it in an article.
Old 06-10-2021, 07:16 PM   #8
Signman
Liked 269 Times in 99 Posts
S&W made a roll bar kit for 3rd gen Camaro a lot like what is used in 4 link suspension installed above the axle housing with torque tube mounted to the body with adjustable links which drop down to the axle housing.
