Old 02-10-2020, 11:39 AM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Stock eliminator Lifters
Looking for recommendation on which lifter and why?
Trend or Precision?
Would you get them DLC coated?
littlemanjoe is offline   Reply With Quote
Old 02-10-2020, 12:54 PM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Stock eliminator Lifters
Trend or Precision?
Both are great lifters and yes, DLC coating helps.
Old 02-10-2020, 03:19 PM   #3
nolongerracing
Liked 72 Times in 27 Posts
Trend or Precision?
You can not run the coated lifters on a cast cam.
nolongerracing is offline   Reply With Quote
Old 02-10-2020, 07:54 PM   #4
littlemanjoe
They will be on a steel cam.
Old 02-10-2020, 08:27 PM   #5
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Cool Re: Stock eliminator Lifters
why can you not run the coated lifters on a cast cam.?
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 02-10-2020, 10:16 PM   #6
SSDiv6
You should be more specific as regards to the type of coating. There are some coatings that can be used with cast camshafts. However, DLC coated lifters can only be used with a properly finished tool steel camshaft core.
Old 02-11-2020, 12:04 PM   #7
rod butcher
Liked 132 Times in 27 Posts
Will wipe out cam lobes.
rod butcher is offline   Reply With Quote
Old 02-11-2020, 03:07 PM   #8
littlemanjoe
Would you get the EDM hole in the face of the lifter?
Old 02-11-2020, 11:02 PM   #9
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
Ppp lifter have a coated lifter with a coating that is safe for a cast cam. In my spare engine I took out the shubeck grenades and installed them on a cast cam. Broke them in as if it was a new cam and lifters with break in oil. Valve setting never moved. Took them all out after to inspect them and they looked like they came out of the box.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 02-12-2020, 09:09 AM   #10
ron mattson
Liked 67 Times in 30 Posts
On billet or tool steel cams I would run the
dlc lifters with no oil hole as the hole just creates
a place for the dlc to not stick or flake off.
On cast cams I would use the ones with the hole
and have coated with a lubricity coating like
Micro blue, have the cam nitrided and coated also.
And as Bob said Pppc has a dlc that will work
on a cast cam also.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
