Old 02-11-2020, 12:04 PM   #1
rod butcher
Liked 132 Times in 27 Posts
Default Re: Stock eliminator Lifters
Originally Posted by Bill Bogues View Post
why can you not run the coated lifters on a cast cam.?
Will wipe out cam lobes.
rod butcher is offline   Reply With Quote
Old 02-11-2020, 03:07 PM   #2
littlemanjoe
Liked 75 Times in 28 Posts
Would you get the EDM hole in the face of the lifter?
littlemanjoe is offline   Reply With Quote
Old 02-11-2020, 11:02 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Ppp lifter have a coated lifter with a coating that is safe for a cast cam. In my spare engine I took out the shubeck grenades and installed them on a cast cam. Broke them in as if it was a new cam and lifters with break in oil. Valve setting never moved. Took them all out after to inspect them and they looked like they came out of the box.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 02-12-2020, 09:09 AM   #4
ron mattson
Liked 69 Times in 32 Posts
On billet or tool steel cams I would run the
dlc lifters with no oil hole as the hole just creates
a place for the dlc to not stick or flake off.
On cast cams I would use the ones with the hole
and have coated with a lubricity coating like
Micro blue, have the cam nitrided and coated also.
And as Bob said Pppc has a dlc that will work
on a cast cam also.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 02-12-2020, 11:39 AM   #5
littlemanjoe
Ron, Your saying nitride my steel cam and use DLC lifters correct?
Do you guys break in with a lighter spring?
Thank you guys so much for your help. This is my first stocker build and I want it to live.
Old 02-12-2020, 06:45 PM   #6
ron mattson
I would nitride a cast cam for use with tool steel
lifters.
Old 02-13-2020, 06:09 PM   #7
65signet
Liked 49 Times in 22 Posts
I always use a light spring for break in
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 02-24-2020, 10:00 PM   #8
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
How much does a set of Precision or Trend Lifters go for?
Rose Racing is offline   Reply With Quote
Old 12-17-2021, 11:59 AM   #9
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Bob what did the Ppp coated lifter (that was safe for a cast cam) cost?
Merry Christmas, Ray
Glad to see you racing in the US this year!! You were flyiiiinnnn!
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 12-17-2021, 08:08 PM   #10
carlm
Liked 3 Times in 1 Post
Can you clean schubeck lifters in ultra sonic ?
carlm is offline   Reply With Quote
