Liked 53 Times in 17 Posts
Does anyone have or know who makes a Trans yoke for a T350 for a roller tail, with a 6.5 in from center of joint (1350) to the yoke end? Only one I can find is a Moser that's a 6in center to end.
Liked 160 Times in 51 Posts
I didn't go through the full list, but Sonnax has a selection of performance yokes.
https://www.sonnax.com/slip_yokes Good luck!
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
Liked 883 Times in 237 Posts
Every billet 1350 yoke I've used in the last several years is 6" long , roller or bushing .
With the yoke properly engaged into the trans there should be no need for a longer one . If the driveshaft is too short and you need the extra 1/2" to get the yoke into the bearing ,you're setting yourself up for other possible issues . Besides stressing the splines ,the yoke can bind on the spline when the yoke is too far out on the shaft.
Liked 91 Times in 29 Posts
Did you try Mark Williams
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
