Old 10-20-2007, 09:05 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default are trw pistons any good
for a stocker motor or are they just for a standard rebuild?
Thanks
Dave
Old 10-20-2007, 10:56 PM   #2
Speedracer
Default Re: are trw pistons any good
Probably too heavy.
Speedracer is offline   Reply With Quote
Old 10-21-2007, 04:31 PM   #3
Jim Cimarolli
Liked 166 Times in 46 Posts
Question Re: are trw pistons any good
David,
What kind of engine?
Jim Cimarolli is offline   Reply With Quote
Old 10-21-2007, 05:07 PM   #4
David Lee
Thanks for the reply Jim, its going to be a 1975 350 chevy nova in I/SA. The long term goal is to hand it over to my nephew who is now 14 and I will return to racing my Duster. I want to keep him on the straight and narrow and the drag strip and the people there are the perfect examples for him
I think we met long ago in Houston. I was with Jeff Ferguson and Mike Maryonne.
Old 10-21-2007, 05:44 PM   #5
LouisJeffery
Smile Re: are trw pistons any good
TRW pistons work great for LEGAL stocker engines.
Louis Jeffery 3225 STK
LouisJeffery is offline   Reply With Quote
Old 10-21-2007, 06:43 PM   #6
Bruce Witherspoon
Bruce Witherspoon's Avatar
Liked 5 Times in 3 Posts
Thanks
Dave
Dave,
I ran one of those motors for years and I will just say there are better choices. I used the TRW pistons for a while, and they used to be much nicer to the wallet but they have some issues.
Bruce Witherspoon is offline   Reply With Quote
Old 10-21-2007, 07:13 PM   #7
David Lee
Originally Posted by Bruce Witherspoon View Post
Dave,
Can you expain what the issues are. I am not planning on a killer motor, that will come later. In the beginning it will be a bracket car and got to 3 or four div a year if I am lucky.
Old 10-21-2007, 07:32 PM   #8
Bruce Witherspoon
Dave,
I sent you a PM.
Old 10-22-2007, 09:56 AM   #9
Jim Cimarolli
Hey David,
Sorry it took me so long to get back on here. Like some of the other guys have already said, there are a lot better choices out there than the TRW stuff. The machine work in the ring land area is not that good and they are tough on the cylinder walls IMO.
Good Luck, and I do remember meeting you at Houston or Baton Rouge. Jim
Old 10-22-2007, 10:23 AM   #10
Jeff Lee
Jeff Lee's Avatar
There was a time when TRW pistons were affordable and there was little else to offer. Considering the cost of a new set today, those offered by CP, Ross, etc. are not only vastly superior in technology and quality, but the cost difference is negligible. Remember, ring seal and reducing friction is key to a fast engine. Both are difficult (but not impossible) with a inferior piston.
But if you have an old set laying around and just need to get it running on a tight budget, then go ahead. Have somebody prepare a high quality set of rings that are gapped, thinner with spacers and back-cut. Vertical clearance is important and can be adjusted with spacers. But you will not obtain the machining tolerance on the lands as offered by the other race piston manufacturers. Not out of the box anyways.
Jeff Lee 7494 D/S '70 AMX
