Old 11-10-2019, 04:04 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default VP and Sunoco
Fuel Tech
If one track does not have VP or Sunoco.
Will is mess us Fuel Check if needed to go with the other Fuel?
Or Sunoco GTX and Supreme
D
Old 11-10-2019, 04:24 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: VP and Sunoco
Yes.
J.R. Haddad is offline   Reply With Quote
Old 11-10-2019, 04:49 PM   #3
Hacksaw
Liked 315 Times in 178 Posts
Fuel Tech
D
Hey: Name one NHRA track that does fuel check for class cars and does not sell VP, Sunoco or some other brand that is on the accepted list.
Old 11-10-2019, 11:06 PM   #4
Dan Fahey
Dan Fahey's Avatar
Very confused....
FUEL CHECK...
What are they checking for?
Specific Gravity?
Mixing an Unleaded Fuel Sunoco 260GTX and Leaded Supreme.
Both listed as legal fuels would cause a car to be DQed?
This does not make sense..
Not every track has all the blends.
Especially Sunoco 260GTX
Dan
Old 11-11-2019, 12:56 AM   #5
Dissident
Liked 73 Times in 36 Posts
Fuel check is using a dielectric constant meter that has been zeroed against a standard such as Cyclohexane or Indolene. Typically Cyclohexane. IF it passes, ok....IF not, yer outa there regardless of what fuel you claim.That method of NHRA fuel check has been in place for many decades.
Now I heard that if you used some 1,4 dioxane.......well, that is another story. LOL
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 11-11-2019, 06:18 AM   #6
james schaechter
Liked 1,450 Times in 303 Posts
Very confused....
FUEL CHECK...
Specific Gravity?
Dan
We run VP and don’t prefer switching back and forth to Sunoco (which is at more NhRA tracks) so we just plan ahead and bring what we need. That is really all you need to do If the Sunoco xxx is what you prefer. Mixing is a problem, so don’t do it.
James Schaechter 3163 STK
Old 11-11-2019, 08:40 AM   #7
Dan Fahey
Dan Fahey's Avatar
I like the unleaded Sunoco 260GTX the best.
Just do not see it much at the tracks.
Then Forced to run the Leaded.
Old 11-11-2019, 10:18 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 2,019 Times in 606 Posts
I prefer VP fuel and have a distributor close to me. I purchase my fuel there and carry enough with me for the race. Typically I carry about 15 gallons along with me. In the past I have had difficulties with the Sunoco fuel and fuel check so I went back to VP. Very rarely do I have any issues with fuel check using VP C12. If you mix the fuel you will have problems at fuel check. Sometimes if you change fuel and don't get all of it out of the system before the new fuel is put in it can cause it to fail. Best is to pick one type of fuel and have enough on hand so you don't have to go through those gyrations.
Mike Pearson 2485 SS
Old 11-11-2019, 10:37 AM   #9
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
If you want to run an approved fuel that's not readily available, you will need to bring an ample supply with you. Changing fuels at the track will require pumping out old fuel, flushing with your new fuel, and I usually have the fuel tested before I go to the lanes to be sure I will pass.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 11-11-2019, 10:40 AM   #10
1347
1347's Avatar
And Dan, you can call Jason at Insinger and get fuel if it's not available at the track.
Duane Hoven
1342 SS/GT
