Old 11-10-2019, 04:04 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default VP and Sunoco
Fuel Tech
If one track does not have VP or Sunoco.
Will is mess us Fuel Check if needed to go with the other Fuel?
Or Sunoco GTX and Supreme
D
Old 11-10-2019, 04:24 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: VP and Sunoco
Yes.
J.R. Haddad is offline   Reply With Quote
Old 11-10-2019, 04:49 PM   #3
Hacksaw
Liked 314 Times in 177 Posts
Fuel Tech
D
Hey: Name one NHRA track that does fuel check for class cars and does not sell VP, Sunoco or some other brand that is on the accepted list.
Hacksaw is online now   Reply With Quote
Old 11-10-2019, 11:06 PM   #4
Dan Fahey
Dan Fahey's Avatar
Very confused....
FUEL CHECK...
What are they checking for?
Specific Gravity?
Mixing an Unleaded Fuel Sunoco 260GTX and Leaded Supreme.
Both listed as legal fuels would cause a car to be DQed?
This does not make sense..
Not every track has all the blends.
Especially Sunoco 260GTX
Dan
Old 11-11-2019, 12:56 AM   #5
Dissident
Liked 73 Times in 36 Posts
Fuel check is using a dielectric constant meter that has been zeroed against a standard such as Cyclohexane or Indolene. Typically Cyclohexane. IF it passes, ok....IF not, yer outa there regardless of what fuel you claim.That method of NHRA fuel check has been in place for many decades.
Now I heard that if you used some 1,4 dioxane.......well, that is another story. LOL
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 11-17-2019, 12:30 PM   #6
ken robinson
Liked 225 Times in 88 Posts
Regards,
HB2
Dissident
1,4 dioxane acts like an ether. It will pass the fuel check ?
Old 11-17-2019, 10:37 PM   #7
Dan Fahey
Dan Fahey's Avatar
Why do fuels change one day as legal!
Later does not pass?
What fuel blends tend to fail the most?
Old 11-11-2019, 06:18 AM   #8
james schaechter
Very confused....
FUEL CHECK...
Specific Gravity?
Dan
We run VP and don’t prefer switching back and forth to Sunoco (which is at more NhRA tracks) so we just plan ahead and bring what we need. That is really all you need to do If the Sunoco xxx is what you prefer. Mixing is a problem, so don’t do it.
James Schaechter 3163 STK
Old 11-11-2019, 08:40 AM   #9
Dan Fahey
Dan Fahey's Avatar
I like the unleaded Sunoco 260GTX the best.
Just do not see it much at the tracks.
Then Forced to run the Leaded.
Old 11-11-2019, 10:18 AM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,981 Times in 597 Posts
I prefer VP fuel and have a distributor close to me. I purchase my fuel there and carry enough with me for the race. Typically I carry about 15 gallons along with me. In the past I have had difficulties with the Sunoco fuel and fuel check so I went back to VP. Very rarely do I have any issues with fuel check using VP C12. If you mix the fuel you will have problems at fuel check. Sometimes if you change fuel and don't get all of it out of the system before the new fuel is put in it can cause it to fail. Best is to pick one type of fuel and have enough on hand so you don't have to go through those gyrations.
Mike Pearson 2485 SS
