Old 04-08-2019, 04:06 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Radiator under constant pressure?
On my Olds motor the radiator is always under pressure. Does not or did not over heat when running last weekend. 130-180 tops Even sitting for 2 days later I went out and checked and hoses were rock solid and water blew out when cracking open cap. Do I have air in system? I would have thought in 2 days system would be pressure free
Old 04-08-2019, 04:11 PM   #2
pfordamx
Liked 7 Times in 5 Posts
Default Re: Radiator under constant pressure?
maybe retorque heads, gaskets could be leaking pressure into the coolant system
pfordamx is offline   Reply With Quote
Old 04-08-2019, 06:59 PM   #3
Mark Ugrich
Liked 71 Times in 38 Posts
Does the car have a coolant recovery tank with the correct style radiator cap?
Old 04-08-2019, 07:13 PM   #4
Jeff Stout
It does have an overflow tank. I will look at pressure written on cap. Maybe it is too high.
Old 04-08-2019, 07:42 PM   #5
Mark Ugrich
Check to make sure the hose into the recovery tank isn’t clogged, I’ve also seen the inlet into the tank molded shut or never drilled open.
Old 04-08-2019, 10:17 PM   #6
fastlane
Liked 53 Times in 20 Posts
That is most likely your problem That is the exact problem all the new supercharged Copos are having. And a lower pressure cap will make it worse.
fastlane is offline   Reply With Quote
Old 04-12-2019, 02:56 PM   #7
cad
cad's Avatar
Liked 93 Times in 52 Posts
I had that issue and it was electrolysis. Put an ohm meter in the water and see how many volts you have.
Old 04-16-2019, 06:22 PM   #8
1legjerry
Liked 72 Times in 15 Posts
This is correct. Make sure your radiator is grounded to the chassis. You could also have a issue with a chemical reaction with any additive you may be running in your coolant. I would do a complete flush and add only water.
1legjerry is offline   Reply With Quote
Old 04-16-2019, 08:04 PM   #9
Jeff Stout
Im finishing on healing from surgery. When I can I will check electrolysis in radiator. I know radiator is held in place with rubber and plastic. No metal to metal contact. Currently straight water. I will also vacuum down water system to remove any air in system. I have 2 engine shops stating air locked
