Liked 707 Times in 284 Posts
On my Olds motor the radiator is always under pressure. Does not or did not over heat when running last weekend. 130-180 tops Even sitting for 2 days later I went out and checked and hoses were rock solid and water blew out when cracking open cap. Do I have air in system? I would have thought in 2 days system would be pressure free
Liked 71 Times in 38 Posts
Does the car have a coolant recovery tank with the correct style radiator cap?
It does have an overflow tank. I will look at pressure written on cap. Maybe it is too high.
Check to make sure the hose into the recovery tank isn’t clogged, I’ve also seen the inlet into the tank molded shut or never drilled open.
Liked 53 Times in 20 Posts
Liked 93 Times in 52 Posts
I had that issue and it was electrolysis. Put an ohm meter in the water and see how many volts you have.
Liked 72 Times in 15 Posts
This is correct. Make sure your radiator is grounded to the chassis. You could also have a issue with a chemical reaction with any additive you may be running in your coolant. I would do a complete flush and add only water.
Im finishing on healing from surgery. When I can I will check electrolysis in radiator. I know radiator is held in place with rubber and plastic. No metal to metal contact. Currently straight water. I will also vacuum down water system to remove any air in system. I have 2 engine shops stating air locked
Liked 129 Times in 59 Posts
Jeff - I would think that if you had air trapped in the cooling system you would experience a problem with overheating, which doesn't seem to be the case. Is this a "new" issue you're experiencing or has this been going on for a while? The reason I ask is because if the cooling system is working properly, there is no reason why the pressure shouldn't remain (it's a sealed system) and usually when the pressure drops it's because of a leak somewhere. The pressure is regulated by the rating on the cap, so anything above that number goes to the overflow tank. If you have a Stant (or similar) radiator tester they have a way to check the cap as well.
Hope the healing process goes quickly. Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
