Old 04-05-2019, 02:26 PM   #1
jrdyno
Default 73 340 or 74 360 for stock?
Have a Duster. Wanting to build for stock eliminator. Both engines fit same
class with 360 car holding a few more pounds.
jrdyno is offline   Reply With Quote
Old 04-05-2019, 07:19 PM   #2
GTX JOHN
Liked 2,425 Times in 687 Posts
Default Re: 73 340 or 74 360 for stock?
Either one work OK.
Both are factored pretty hard and
not cheap to build competitively.
John Irving
741 Stock
741 Super Stock
Old 04-06-2019, 03:55 AM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by GTX JOHN View Post
Either one work OK.
They are good looking machines though.
Lots of available parts to make them competitive.
Old 04-06-2019, 08:55 AM   #4
Gmirza
Liked 247 Times in 92 Posts
If you have the parts the low compression 340 is a great motor. I think they are more durable than the 360. The pistons are fairly lite, the small main bearings and the small valve heads have good velocity, making a great reving little motor. It doesn’t make enough power to beat itself up.
For the most part the racers have maxed it out, so you won’t be seeing any big hp changes.
From what we have learned over the years is the only thing a 340 and 360 have in common Is their appearance. They are two completely different animals. What works on one doesn’t work on the other.
Look at the Vegas qualifying, 4 or 5 340’s and 1 360.
George Mirza
Gmirza is offline   Reply With Quote
