Old 01-06-2019, 07:43 PM   #1
btrc
Liked 84 Times in 42 Posts
Default FE Ford questi
This isn’t a S/SS question but I know i can get a good answer here. When I retired from drag racing the first time about 30 years ago I built a 427 Cobra replica with a low riser 427. A while back I put on Edelbrock heads and a single 4 intake. I’ve been thinking about putting the low riser 2- 4 intake back on. Will the step from the intake to the heads cause any drive ability issues? I’ve heard it is not a big deal. This isn’t a race car so I don’t need max power for a 2300 lb car.
Thanks
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 01-07-2019, 09:58 AM   #2
pmrphil
Liked 401 Times in 154 Posts
Default Re: FE Ford questi
I can't see how it can hurt driveability, the smaller runners may even help a bit.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 01-07-2019, 11:27 AM   #3
btrc
I believe the floor of the ports in the low risers intake are lower than the floor of the heads so there will be a step up to the heads.
Bob Tilton
568 FS/H
Old 01-07-2019, 02:30 PM   #4
lorenr
Liked 19 Times in 9 Posts
Lightbulb Re: FE Ford questi
Something similar happened on 460 fords used on jet boats. They used a standard 460 engine and added a Cobra Jet style intake manifold. The CJ intake ports being much larger than the small port cylinder heads. No one that took the engine apart could figure why there were not issues. However, the motor ran fine, in fact it made more power with the CJ setup than the standard four bbl manifold.
I'd do it. Probably be fine. The only problem I can see is that every time I've switched from 2-4's to a single 4 bbl on a good intake, I've made nearly the same power and it always ran better.
Lorenr
lorenr is offline   Reply With Quote
Old 01-09-2019, 11:37 PM   #5
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Lorenr
I had a 22' Donzi with an OMC 460 and King Cobra outdrive back in the day. You are absolutely correct about the intake manifold. It had the big port CJ intake and the smaller port heads with a huge mismatch. That was all factory as Ford built the marine 460. I believe they quoted a 20-30 hp with the CJ intake?
b.guggenmos is offline   Reply With Quote
Old 01-10-2019, 09:49 AM   #6
Ralph A Powell
Liked 227 Times in 138 Posts
You are correct on the HP gain if can find the old Ford Muscle Parts book from Ford the show that up date.
Ralph A Powell is online now   Reply With Quote
