Old 07-15-2018, 08:11 PM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Default Brake problem
Went from no problem holding the car at 3000 rpm on line to pushing thru the beam. Four wheel wilwood disc brakes.Mopar master cylinder( don't know piston diameter).Checked the pressure at each wheel. 1000 lbs coming out of master going to front brakes. 1000 lbs at front wheels. 800 lbs at rear and it will go no higher no matter how much more pressue you build up. I didn't have an adapter to measure pressure coming out going to rears.Couldn't swap lines from front to rear on master (different sizes). 3/16 lines going to fronts and 1/4 going to rears.
